Anyone know what size jet needles are on my XS360, and would MikesXS carry them? Or, any other source, for that matter?
main 135
air jet 0.6
jet needle 4fp21-3
needle jet X-6
pilot 17.5
starter jet 40
I guess you contact mikuni for parts
Hey Drewps. Yeh, I saw you post that on another thread, but I can't find 4fp21-3 needles anywhere (a google search directs me to that one thread). I did go to mikuni, looked thru some of their destributors...lotsa needles, but none with that number.
Where did you get those numbers?
Here's the biggest list of mikuni jet needles I've found thus far:
4J13 4J13 $3.95
5DP7 5DP7 $3.95
5FP17 5FP17 $3.95
5L1 5L1 $3.95
6DGY04-59 6DGY04-59 $3.95
6DH2 6DH2 $3.95
6DH3 6DH3 $3.95
6DH4 6DH4 $3.95
6DH7 6DH7 $3.95
6DH8 6DH8 $3.95
6DJ30 6DJ30 $3.95
6DP1 6DP1 $3.95
6DP17 6DP17 $3.95
6EJ12-55 6EJ12-55 $3.95
6EJ12-56 6EJ12-56 $3.95
6EJ12-57 6EJ12-57 $3.95
6EJ12-58 6EJ12-58 $3.95
6EJ12-59 6EJ12-59 $3.95
6EJ12-60 6EJ12-60 $3.95
6F4 6F4 $3.95
6F5 6F5 $3.95
6F8 6F8 $3.95
6F9 6F9 $3.95
6F15 6F15 $3.95
6FJ40 6FJ40 $3.95
6FJ41 6FJ41 $3.95
6FJ6 6FJ6 $3.95
6FL14 6FL14 $3.95
6FM46 6FM46 $3.95
6N1 6N1 $3.95
7DH2 7DH2 $5.50
7DH3 7DH3 $5.50
7DH4 7DH4 $5.50
7DH5 7DH5 $5.50
7F6 7F6 $5.50
7F7 7F7 $5.50
oh I guess there buggered you may be able to get around the problem by adjusting the clip position. but don't forget to look at the diaphragms when you have the slides out if they are brittle they could be recovered with GT85 or WD
Regards Jim
Naw, they're worn out enough to warrant replacing. On both carbs somewhat, but especially the left one.
are they the same as XS400?
the 400's use the same carb, but have different jetting and needles
main 135
air jet 0.6
jet needle 4fp21-3
needle jet X-6
pilot 17.5
starter jet 40
So Drewp, where u get all them part numbers from? To add confusion to the mix, I looked up the yamaha part number for that jet needle: 1L9-14116-21-00.
I guess I'll try the yamaha dealership next.
try speed & sport, they seem to have amassed lots a yam spares
BTW they aren't part numbers, they are specs from mikuni via haynes manual.
Naw, no luck with Speed & Sport. Thanks for the help, boys.
Yup, tried there already. Alas, no XS360 anything there. :(
Oh man, this has become an insurmountable obstacle, I tell ya. I called the yamaha dealership today. They couldn't track it down by the mikuni spec number, but did find the yamaha parts catalog number...and it's discontinued. And, no available cross reference for a comparable needle replacement. His advice was sniff out the needles on ebay.
Well then, heard it from the horse's mouth, spoke to mikuni themselves today. These needles were made exclusively for the XS360, and are now utterly discontinued...with no cross referencing or aftermarket support that mikuni knows of. So, I'm basically SOL unless I find somebody hoarding new old stock needles. Unreal.
Try siriusconinc
Try siriusconinc
read the posts OG, Bindun!!
why don't you try 400 barrells/pistons etc and run the 400 carbs if you get stuck?
Just noticed that Drewpy, but did G man use the "Contact us" route? I would as its getting difficult, just cause theyre not listed does'nt mean they have none does it?
Ok, so if I do run the XS400 jet kit on the XS360...wait, why can't I run the XS400 kit, anyways? What would I likely have to do to make that work, ie, drop the needles, toss on pods, etc?
Oldgit, I didn't email Sirius, but I did Sudco. Haven't heard from them, yet.
True.....
hope you like my new avatar :moon:
True.....
Atavar's cool but theres no GT85 got to fair to both !
True.....
Just a dab will do ya.
