November 5, 200817 yr Hi all, i have a 2001 TDM 850 and would like to ask that when i pushed the start button i get a loud bang from the exhaust and the engine did not start at this morning. After several seconds i attempted to start again and it started immediately and all was normal after that. In the past couple of weeks the same situation had happened three times after not using the bike for 3 or 4 days. Can anyone has an idea why this occurs? Thanks in advance.
November 5, 200817 yr Hi all, i have a 2001 TDM 850 and would like to ask that when i pushed the start button i get a loud bang from the exhaust and the engine did not start at this morning. After several seconds i attempted to start again and it started immediately and all was normal after that. In the past couple of weeks the same situation had happened three times after not using the bike for 3 or 4 days. Can anyone has an idea why this occurs? Thanks in advance. HI/ Sounds like the fuel is running thru [ float sticking] turn off petcock b4 shut-off c if improves..
November 6, 200817 yr Author HI/ Sounds like the fuel is running thru [ float sticking] turn off petcock b4 shut-off c if improves.. Thanks, i will try.
November 20, 200817 yr Author HI/ Sounds like the fuel is running thru [ float sticking] turn off petcock b4 shut-off c if improves.. There is not a petcock on 2001 TDM 850. I don't know what to do.
November 20, 200817 yr Moderator There is not a petcock on 2001 TDM 850. I don't know what to do. Got a centre stand? If yes use that when you leave the bike for any time.
November 21, 200817 yr Author Got a centre stand? If yes use that when you leave the bike for any time. She has a centre stand. I tried to use it but nothing has changed.
