November 4, 200817 yr Hi All, Is there any way of increasing the sound level or getting a more noticeable note out of a standard FAZER 1000 exhaust can (mine's an '05). Has anyone done it? The standard can seems to perform ok but is dangerously quiet startling every car driver you pass as they never seem know you've been behind them for the last mile or two. It seems a shame to have to replace the std can with an aftermarket item in the interests of rider safety, I'm not looking for more power, its got plenty and the bike's perfect as far as I'm concerned. I just want to advertise I'm there as I'm getting fed up with dopey drivers not looking in their mirrors. Best regards to all.
November 4, 200817 yr hi buddy, i have the same bike exept an 01 model. My advice would be stick an Akropovic can on it.the one i have sounds and looks superb! but not enough to upset the local costabulary.mine does have a baffle you can fit if it's a bit loud but mine sounds really quiet when i fit it. cheers Marcus
November 4, 200817 yr Author hi buddy, i have the same bike exept an 01 model. My advice would be stick an Akropovic can on it.the one i have sounds and looks superb! but not enough to upset the local costabulary.mine does have a baffle you can fit if it's a bit loud but mine sounds really quiet when i fit it. cheers Marcus Marcus, Thanks for the tip mate I'll check 'em out, I guess it's the only way really. Does the bike require any tuning afterwards for optimum running or is it just 'plug & play'. Rgds,Steve.
November 5, 200817 yr Could you simply drill a series of small holes in it? This would definatly change the sound not sure if it would be a good adea all the same. Conor
November 6, 200817 yr Author Wow, the drill holes sound interesting. Any proven method? i.e. what size and how many etc.......anyone else done it? Used standard cans are easily obtained from e-bay, so I'll experiment, If I'm unhappy with the noise I might just cut it open and post the internal pikkies on this site. Regards, S
