Hi,
hope one of You gals/guys can help.
The What:
Bolts for securing the caliper to the front fork:
M10x35, pitch 1.25. But no specs regarding strength or material. -Oh, theres a mark
on the top: "9" (or "6" - if You prefer). :-/
I've found a lot of offers on the net, but most seem undocumented, when it comes to
decide, whether it's suitably strong or not. I simply don't know enough.
The Why (You can skip this, unless You /really/ want to know, how I made a complete
arse of myself - and maybe nearly turned myself into pulp):
The day after a (successfull, albeit late!) swap of the front fork oil seals, I went my
merry way to work and back. On the way back, doing 70 mph, something hit my shin,
then sommersaulted up and away. I thought some unfriendly thoughts about people with
trailers, that fail to secure their load. I reached home - and found out I must have forgotten
to fasten the bolts, that fix the front caliper to the fork. The remaining one could be pulled
out by hand. 'nuff said.
That's all folks!
Per Termark,
Herfølge,
Denmark
you can either get one from Mr yamaha, (for the 9 or 6) or go to local shop and buy a normal high tensile steel bolt.
people use stainless which is not as ductile (ie the threads don't stretch as much to hold the part on)
Hi drewpy,
thanks for taking the time.
I guess that refers to the site(s) mrcycles.com/mryamahaparts.com? -Never heard of the guy, but I didn't find anything
there - though I'm sure it might be there, if I only knew what to look for! *G*
As to the local shop: Hardware-shops are scarce here-abouts - they're run out of business by huge
DIY-stores, whose philosophy seems to be "One bolt fits all". No 1.25 pitch bolts there - I checked. <_<
Apart from that, all the good stuff (documentation-wise) is written in either english/german - possibly french -
and although I'm not completely illiterate, my native language is Danish. And so is that of the guys in the DIYs,
so asking for "high tensile steel" might be pushing it. -Or the steel-savy employee might ask me
"Would that be by the A4 (VA4), 8.8 or perhaps a 9.4 grade ISO/DIN standard, sir?" and I'd go: "No habla Metallurgy, senõr".
Well, we've got a friend, who's an auto-mechanic who _just_ might have a likely part - if not, I'm of to the
"tasty nuts"-site - this one looks like it might do the job.
(How did they come up with that site-name?).
"No habla Metallurgy, senõr". This stuff's got a learning curve like linux. Steep. And I suffer from vertigo.
Enough ranting for now. Again, Thanks for taking the time.
Per Termark
sorry, I meant a local yamaha dealer.
try here
www.cmsnl.com dutch site mail order
you can also try some rd aircooled online shops as some early rd had the same caliper.
Sr 250 and Sr500's also have the same caliper.
try german ebay shops (www.ebay.de) and use google online translator to decipher what is being said or look at the pictures!!
Hi,
I called one of the most well-established Yamaha-dealers (I work in the capital, Copenhagen), but
without a partnumber he couldn't do anything, apart from rummaging through used parts in a box. :(
And - he let it slip, that he's got no way to crossreference.
Yup - found it half an hour before I noticed Your post - after way to many hours sifting through
no-good'ers. Seems an excellent site. :thumb:
Excellent tip! Did anyone compile such knowledge in one place? If so, I'd be happy to provide some
space for a mirror - if not, I think I might better start using some of those dearly bought, never used,
gigabytes. :icon_wink:
It's mostly part-names that defers(?) my knowledge of german, but I actually came across a (possibly
discontinued) german site, with a german<->english partlist; "Hauptstäender" = "Centre stand".
If anyone want it, I'll dig it out again. If so, would there be any place in particular to post it?
Tchüss,
Per Termark
