temp gauge
luke203
This post is 5708 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Check the connection at the sender unit (be around the thermostat), use a suitable earth and earth the connection see if the gauge moves. If it does its the sender unit, if not its the gauge or the wiring.
