October 20, 200817 yr hi new to this site,my 2003 fazer is only fireing on middle two cylinders,carbs are ok,coils ok has anybody got any idears please thanks ron.
October 21, 200817 yr It's a coil. 99% certain. Usually have one feed 1 + 4 the other feed cylinders 2 + 3. Check the connections into the back of the coil first. Have a wander over to the Fazer Owners Club too if you can't make progress. http://fazerowners.yuku.com/bfazerowners Paul Assuming that you've got fuel etc in the cylinders...
October 21, 200817 yr Author It's a coil. 99% certain. Usually have one feed 1 + 4 the other feed cylinders 2 + 3. Check the connections into the back of the coil first. Have a wander over to the Fazer Owners Club too if you can't make progress. http://fazerowners.yuku.com/bfazerowners Paul Assuming that you've got fuel etc in the cylinders... hi paul,i have tested tha 1and 4 coil in place of the 2 and 3 coil and it works fine on 2 and3. there is petrol in carbs .i will have a wander thanks ron
October 23, 200817 yr Okay, Coil-related as 1+4 affected and the coil is fine - either power/earth out the back of the coil, connection over to the TCi or connection from the pick-ups up to the TCi... Did you make any progress on sorting this? Paul
October 25, 200817 yr Author Okay, Coil-related as 1+4 affected and the coil is fine - either power/earth out the back of the coil, connection over to the TCi or connection from the pick-ups up to the TCi... Did you make any progress on sorting this? Paul [/quote hi all sorted ,the problem was with the carbs. and we think dodgy petrol,thanks for all your advice.Ron
