04 dtr 125
my dtr wont start first time it takes ages but when i do get it goin i ave to keep revin the bike bcause if i dont the bike just stops like its not gettin petrol but i just filled it up it drives fine when i do get it goin but soon has i stop the engine stops
Please help !!!!!!!!
things to start with (maybe):
blocked breather (common on trailies)
knackered spark plug (v. common on 2 strokes)
Loose or corroded electrical connections.
the DT experts on here may know better than me! (i havent had a 2 stroke for yonks!)
cheers m8 i put a new plug still doesnt work lol it doesnt start by the electric start i have to bump it lol
Would i be right in thinking it starts ok on starter jet or choke ? (whichever is fitted) and then dies when you turn that off unless you keep the revs up?
Have you tried adjusting the throttle stop as on my old DT/LC it works loose!!
Yes mate has soon has i put the choke back down it goes to die till i rev it
Will it tick over on starter jet, like peatandyman said, If it will then it looks like a blocked pilot jet in the carb.
il give it a good cleaning tomorrow and c what happens.
Thanks for all your help.
cheers lads for your help got the bike going again the carb needed a gd cleaning
