October 16, 200817 yr just changed my exhaust for a big one . need someone to help me on the original exhaust a pipe was connected to it i presume it is a breather pipe, on the new exhaust there is no where to put this. what can be done with this . please help as i dont know what what the pipe is and what it does and will leaving not connected damage anything.
October 16, 200817 yr Hiya mate, does this come from your air box,if so it's your hot air feed,wont do any harm plugging it at the air box end.This is assuming it's from your air box,check 1st
October 16, 200817 yr Author Hiya mate, does this come from your air box,if so it's your hot air feed,wont do any harm plugging it at the air box end.This is assuming it's from your air box,check 1st cheers will check where its connected thanks for replying
October 16, 200817 yr Im not sure about big ones but the dep has a bung to block the pipe (once taken off metal pipe) and a cable tie to hide the hose above the carb in a safe place. hth
October 17, 200817 yr Author Im not sure about big ones but the dep has a bung to block the pipe (once taken off metal pipe) and a cable tie to hide the hose above the carb in a safe place. hth cheers mate ,will give it a go
