Posted October 15, 200816 yr 78 xs 400. For some reason fuel is accumilating in the carb adapters...I dont know why. Needle and seat appear to be fine, one float had a hole but I soldered it shut. I rebuilt the pet cock. If any one could help.
October 15, 200816 yr Moderator 78 xs 400. For some reason fuel is accumilating in the carb adapters...I dont know why. Needle and seat appear to be fine, one float had a hole but I soldered it shut. I rebuilt the pet cock. If any one could help. Soldering floats up can sometimes add weight and therefore affect buoyancy of the float this then leads to higher fuel level in the bowl.is the problem only on the cylinder with the repaired carb?
