lower xt660r
Hello.
I have a xt660r, but it is to tall for me, how can i make it lower? what do you recomend?
try to rise the front fork 3cm, put the rear shock on the lower regulation? i know that there are some kits to rise/lower thr rear suspencion, but that is too radical.
Thaks.
About your only option is a lowering kit, compressing the pre-load just makes it harder, and paradoxically harder for you to reach the ground (as the suspension isn't compressing when you sit on it). You've not much to go the other way either (softening it) as the factory settings are only a notch ot two from the softest.
Suggest you have a look through the 660 site - www.xt660.com, you'll find loads of information on there specifically for your bike, from lots of others who have 660's. See you there!
