divvy driving me nuts
my bike is driving me nuts. About a week ago number 3 cylinder went down. Soooooooo i changed the plugs cleaned the carbs and air filter. there is fuel in the float bowl , when i take the plug out its wet.
So today i switched the coil packs over and the problem still exist.
Can anyone chip in with anything else I should look at ,
cheers very much
Hi, can you explain this in more detail?
Thanks for the reply.
In response number 2 cylinder does not fire and the header pipe remains cold. I have taken of the carbs and cleaned them out , problem still exist.
I changed the plugs and no change. I tool the plug out and noted that the plug was wet. There is fuel in the carb bowl.
So i thought that it might be the coil pack so i swopped the coil packs over and the problem is still there . I was going to buy a compression tester and see if there was compression in cylinder two . Any advice greatly appreciated.
