Confusing engine problem
what has been done so far.........
fuel tank cleaned.all fuel filters cleaned..petrol pump check and all ok
run with air box split to view carbs still the same.new airbox rubbers fitted no change
replaced carbs with a good set off a running bike.my old ones are on my mates and are fine. still no change
checked that manifold rubber are ok.......... they hold a good vacuum on inlet no air leakage
check thro' electrical system coils generator.. all to spec....new plugs and plug caps fitted
new regulator fitted new battery fitted
remove thermostat to check to see if it opens at correct temp
run engine from cold and revs freely till the temp gets up
remove air box when fault occurs.revs freely when no load
road test with airbox of struggles to get above 5k.but i'm guessing thats a mixture prob with no airbox on
so can you think of anything else i've missed
Have you tried a commpression test (warm and cold) ive come across bikes with dodgy rings showing similar symptoms!
that is my next test to do at the weekend.......... got tot the point don't care what the problem is just what to get the damned thing fixed.....lol
Sometimes if it is the rings you can smell petrol through your oil filler cap!
