October 6, 200817 yr I have noticed in the last few days that I am struggling to get my R125 over 63mph and that is at 80,000 revs in top gear. I can usually get 73mph out of it. Is anyone else having or had a similar problem and can anyone think of what the problem may be before I get it checked out?
October 6, 200817 yr that is at 80,000 revs in top gear. wow 80,000RPM jeeezz thats alot... sorry dunno mate you checked your plug is tight...and the gap.ur aifilter is not clogged?
October 6, 200817 yr Moderator I have noticed in the last few days that I am struggling to get my R125 over 63mph and that is at 80,000 revs in top gear. I can usually get 73mph out of it. Is anyone else having or had a similar problem and can anyone think of what the problem may be before I get it checked out? If you once got 73mph @8000rpn and now you get 63mph @ 8000rpm Then it is clutch slip!! Have you changed oil recently, full synthetic oil can cause this, or did you thrash it to death during its short life and wear it out? Make sure you have a few millimeters free play at the lever before it starts to pull on the cable, adjust as necessary!
October 6, 200817 yr Moderator Think Oldgit is on the case here...... Does sound like a possible clutch issue.
October 6, 200817 yr Author The bike is less than 6 months old so I have basically done not much to it. I checked the oil and it is still fine and as for the clutch it feels ok. I did find that on a few occasions when I started it it was very 'spluterry', but I put this down to the cold weather as it had been outside for several hours and it was 3am.....
October 6, 200817 yr Moderator and as for the clutch it feels ok. It may feel ok, Theres no different "Feel" even when its toast!! But the symptoms suggest fooked, or at least that an adjustment is needed either at the lever or if thats still got free play, then at the pushrod adjuster (If its got one)
October 6, 200817 yr Moderator and as for the clutch it feels ok. It may feel ok, Theres no different "Feel" even when its toast!! But the symptoms suggest fooked, or at least that an adjustment is needed either at the lever or if thats still got free play, then at the pushrod adjuster (If its got one) Double post not intended...sorry, damned pc
October 6, 200817 yr you could always try draining it out see if you can spot any "fibres" in the oil.
October 7, 200817 yr If the bike is less than 6 months old, take it back to where you got it from and have them look at it as it must still be under warranty?
October 7, 200817 yr Author If the bike is less than 6 months old, take it back to where you got it from and have them look at it as it must still be under warranty? I have booked it in.....
