My RD350LC11 ypvs keeps filling the exhaust up with fuel and also holds back at about 60mph. Can some one help? THANKS
Sounds like your not firing on all cylinders ;) . If you are getting gas in the exhaust then the cylinder would not be firing for some reason. That would also cause top speed to be limited.
;) Thanks. I've put New plugs in and checked the timing ,thats all fine.It does'nt seem to be missing.Any other ideas? :rolleyes:
Both exhausts or just one, do both exhausts get hot at the header pipe?
Both Pipes and yes it does get hot at the header pipe. :D
This is a new one on me, that is some fuel burns and some does'nt, Never had a power valve bike myself but i'm wondering if this could be the culprit, ive heard they can stick, somehow they rotate in the exhaust port i think, can you check its workink correctly, have you got a manual etc etc, try you tube too, sometimes people put useful stuff on there!
