Posted September 24, 200816 yr i was riding round last night on my DTR as i usually do then i heard clonk clang and it cut out, i go to kick it back over the kick start is solid. so I'm think seized (oh s**t) my mum then told me try bumping it so i did the kick start became free again but wouldn't kick over so i bumped it again and it started 2 go then it kept backfiring and wouldn't go faster than bout 10 MPH. if any1 knows anything please help my lil bike
September 24, 200816 yr Moderator i was riding round last night on my DTR as i usually do then i heard clonk clang and it cut out, i go to kick it back over the kick start is solid. so I'm think seized (oh s**t) my mum then told me try bumping it so i did the kick start became free again but wouldn't kick over so i bumped it again and it started 2 go then it kept backfiring and wouldn't go faster than bout 10 MPH. if any1 knows anything please help my lil bike You should stop riding it straight away, sounds like something has come adrift, I suggest you check the generator flywheel hasnt come loose
September 24, 200816 yr Oh mate, sounds like it sized up,two stroke will sizeup ,then when they are cool they will free of a bit,but what happens is the rings damage the cylinder, resulting in compression loss ,look like you need a top end rebuild,Parsley
September 24, 200816 yr Oh mate, sounds like it sized up,two stroke will sizeup ,then when they are cool they will free of a bit,but what happens is the rings damage the cylinder, resulting in compression loss ,look like you need a top end rebuild,Parsley were are you? if you are in the norwich area & can get it to me, ill fix it for you Parsley
September 24, 200816 yr Author when i get home 2 night i'm going 2 strip the carb nd shiz wid ma mate and c if we can find the problem
September 24, 200816 yr i had a cr 250 what done that and it turnd out the pin what keeps the conrod in place hade come loose and it needed a rebuild
September 26, 200816 yr definetly a rebuild if u notice the bike starts gettin faster it usually meens it on its way out so fetch your self piston and rings sharpish barrel only nee doin every 2 blow ups unless brain cell tries bumping it which will then makje your rings 'eat' your barrel cheers DTXracer
