Carb Removal - how ?
Hi,
I'm trying to remove the carbs from my 1995 FZR600 (Foxeye Model) - my Haynes Manual isn't much help.
Do the carbs come off as a complete unit or one at a time - pls help ??????????????? :blink:
Kawasakifreak
As far as i know they should come off in one comlete unit, and should look like this:
Im sure someone with more knowledge of this bike will be along shortly to tell you a bit more. ;)
The carbs come off in one complete set (as goff said), you loosen the retaining clips (or jubilee clips, which ever's fitted) between the airbox manifolds & carbs, then the same between the carbs & inlet manifolds to the head. Then twist the carbs out of the manifolds & push out the carbs (usually to the leftside of the bike when sitting on it). Obviously after removing fairing, panels, seat & tank. On some bikes it may be necessary to loosen the airbox to pull it backwards to provide more room to manouver the carbs. Fitting is the reverse of removal.
