September 18, 200817 yr I have a 81 xs400 spII with drum brakes how much trouble to change to disc on the front. I also want to change from spokes to mags. what front forks will interchange easy? Will the mag wheel in the back just bolt on like the spoke rim?
September 18, 200817 yr I have a 81 xs400 spII with drum brakes how much trouble to change to disc on the front. I also want to change from spokes to mags. what front forks will interchange easy? Will the mag wheel in the back just bolt on like the spoke rim? The rear wheel will be a bolt on swap with the alloy made for the XS400, this is actually something I'm doing. As for the front, you will need a new fork to do the swap. My bike has an XJ550 front end on it with a 19" alloy wheel and disc brake.
