matching keys
hi everyone.
my DT50 ignition key doesnt fit the steering lock or the other lock under the back seat (cant hink of what its called)
is there a way i can get either a steering lock, ignition switch and lock that uses the same set of keys (i.e. buy them as a whole set) or somehow get a key cut to fit the original locks?
- Steve
You`ll need to buy a complete lockset, probably expensive from a main dealer or try Ebay.
Most proper locksmiths will be able to cut a key to suit the lock, my brother had one cut to fit his bike, just needed to remove lock and leave it with shop.
Decent Lockies and cutting shops should be able to impression the lock and cut suitable keys without having to remove them at all.
They do it with cars all the time.
You can even make one yourself out of a hacksaw blade.
Plenty of guides on the internet that explain how - They can then cut a proper one from that.
Some locks have a code on them that can be used to form keys.
well im getting a spare ignition key cut tomorrow so i will ask at Timpsons and see if they can do anything
If you have one, try a smaller independent key place.
Often cheaper and more capable than the chain places!!
Edit: Pop over here to Reading and enquire at the Key/Shoe place in the Broad Street Mall.
