help on what carbs these are off of.
got these with a pileOparts, two banks same carbs. help ID thanks.
Have a look on the end of them, on the flat on the float bowl. Is there a 3 letter code there?
THESE are of a 1991 FZR1000 EXUP RU
Yours look very similar.. Probably YZF 750 Or FZR 600 / 750
There must be a 3 digit code or ID letters on them somewhere. That's the only way you're going to know.
ill check for the #'s and post them up.
well numbers vary ea set.
3HH 00 E824
the other set has the 3 symbols rubbed of, following are 04 T365.
thanks for any help.
3HH is 90s FZR600 I believe.
I would ring your Yamaha dealer with these numbers and see what they can tell you. :)
