September 13, 200817 yr Have a look on the end of them, on the flat on the float bowl. Is there a 3 letter code there?
September 13, 200817 yr THESE are of a 1991 FZR1000 EXUP RU Yours look very similar.. Probably YZF 750 Or FZR 600 / 750 There must be a 3 digit code or ID letters on them somewhere. That's the only way you're going to know.
September 13, 200817 yr Author well numbers vary ea set. 3HH 00 E824 the other set has the 3 symbols rubbed of, following are 04 T365. thanks for any help.
September 14, 200817 yr 3HH is 90s FZR600 I believe. I would ring your Yamaha dealer with these numbers and see what they can tell you.
