my problem is my bike runs too rich between 2 and 4 thousand revs, meaning it goes sloppy and makes for poor handeling.
the guy whos serviced my bike and dynod it has recomended a dynojet kit. do i really need ti though? will it solve the issue?
cheers
david
R6's don't get going until 4000rpm anyway, so to be honest your unlikely to notice much performance difference, all though it could smooth out the throttle responce a bit, however if you lean it out the engine will run hotter and maybe this isn't a good thing at lower revs.
cheers
david
It's not on cam at those revs so that is why its a little bit rich. There would be no pick-up if it was weakened off. I suppose that you exup valve is working, or is it a Honda.
the only reason im considering it, is because its so bad that the bike stalls on me at junctions, or when i try to control it at low speeds. i give it some revs and it kicks in two heartbeats later and spins off like a rocket.
