fzr 600 jumps out of 4th gear
hi,recently bought a fzr 600.its tatty but will clean up and the engine is sweet as a nut.the anoying thing is it jumps out of 4th when you give it some.can anyone advise me,can i fix it,is it a garage job.if so would it cost alot
Hi there,
From the sound of things it's either the selector arm that is damaged or the syncromesh on 4th gear,in any event unless you are a compotent mechanic its a garage job as its engine out and split to get to the gearbox so it will be expensive. If you are going to give it stick try keeping your foot on the gearlever when you put it in fourth that should work for a bit while you decide what to do ?
Regards
Bill
hi bill,thanks for your reply.ill try the foot under the the gear lever.someone at work sugested a second hand replacement engine and it sounds a good idea to me.cheers.
