Hi All,
Took the air box off my fzr to replace air filter and managed to pull the thin pipe that connects underneath off the bottom out of engine bay, I cant see where it is supposed to connect.
Anyone help?
Cheers
Mike
That's a breather pipe, right?
If it's anything like the 1000, then there is a bracket with a metal bit of pipe sticking out, below the carbs, near the crank.
Or it's a pipe that sticks out of the Crankcase.
HTH
Olli
HTH
Olli
Theres two pipes, a thick and a thin, the thick one is crankcase breather, thats ok, its the thin one i cant find where to connect,
Cheers
Mike
Cheers
Mike
Wot year is it? I have a haynes manual... can have a look for you :)
Must admit that I know nothing about these bikes, But i'm wondering...Could it be a condensation drain pipe that doesnt actually connect to anything but is routed down somewhere for the water to drain to the road?
Could be, yes, not sure though :D:unsure:
The metal bracket I was describing actually goes nowhere. It's just a breather or drain point, but had a think and that bracket takes 2 breather pipes for the carbs. :blink:
I need a year and is it a uk model?
not for a scottoiler is it?
Hi
Thanks for help, its a 1989 fzr600 3he,
Cheers
Mike
Hi Mike,
I've had a look in the manual and I think it just hangs down like the Oldgit said.
To be sure though, can you take a pic for us?
PM me with it :)
Regards,
Olli
