FZR air pipe
Hi All,
Took the air box off my fzr to replace air filter and managed to pull the thin pipe that connects underneath off the bottom out of engine bay, I cant see where it is supposed to connect.
Anyone help?
Cheers
Mike
That's a breather pipe, right?
If it's anything like the 1000, then there is a bracket with a metal bit of pipe sticking out, below the carbs, near the crank.
Or it's a pipe that sticks out of the Crankcase.
HTH
Olli
HTH
Olli
Theres two pipes, a thick and a thin, the thick one is crankcase breather, thats ok, its the thin one i cant find where to connect,
Cheers
Mike
Cheers
Mike
Wot year is it? I have a haynes manual... can have a look for you :)
Must admit that I know nothing about these bikes, But i'm wondering...Could it be a condensation drain pipe that doesnt actually connect to anything but is routed down somewhere for the water to drain to the road?
Could be, yes, not sure though :D:unsure:
The metal bracket I was describing actually goes nowhere. It's just a breather or drain point, but had a think and that bracket takes 2 breather pipes for the carbs. :blink:
I need a year and is it a uk model?
not for a scottoiler is it?
Hi
Thanks for help, its a 1989 fzr600 3he,
Cheers
Mike
Hi Mike,
I've had a look in the manual and I think it just hangs down like the Oldgit said.
To be sure though, can you take a pic for us?
PM me with it :)
Regards,
Olli
