September 7, 200817 yr Hi again folks, I have got two FJ 1200's 1 3XW with ABS, and a 3CV,The 3XW is scrap due to a siezed gearbox,but I fitted new discs last year,does anyone out there know if all disc are the same,ie will the new discs fit on the 3CV. Many Thanks.....2tone
September 7, 200817 yr Hi again folks, I have got two FJ 1200's 1 3XW with ABS, and a 3CV,The 3XW is scrap due to a siezed gearbox,but I fitted new discs last year,does anyone out there know if all disc are the same,ie will the new discs fit on the 3CV. Many Thanks.....2tone If you go onto Allbike engineerings website you can look up the discs & compare the dimentions to check if they're the same as other models. Alternatively take them off & try the discs against the other bikes wheels.
September 10, 200817 yr Author If you go onto Allbike engineerings website you can look up the discs & compare the dimentions to check if they're the same as other models. Alternatively take them off & try the discs against the other bikes wheels. Yep ! Looks like a new set of front ones is needed due to the ABS centre on the wheel rear looks a close match,might save a few bob there Cheers ..2tone
September 10, 200817 yr Hi again folks, I have got two FJ 1200's 1 3XW with ABS, and a 3CV,The 3XW is scrap due to a siezed gearbox,but I fitted new discs last year,does anyone out there know if all disc are the same,ie will the new discs fit on the 3CV. Many Thanks.....2tone I've got to ask how you siezed the gearbox? If the engine was not shock loaded you could sell it.
