Can I use an XS650 clutch lever/lever bracket assembly (like the ones on mikesxs.com) on an XS400S clutch cable? They look the same from the pics I can find, but want to make sure before I purchase.
I just bought aftermarket ones and they fitted and look the same, so I assume that the ones from Mikes XS will too.
So, just to be sure I get you here, you put aftermarket XS650 levers on your XS400 and it worked fine?
the weren't even marked just generic ones
Huh, well I won't worry about it then.
