September 5, 200817 yr hi all i have a dt125x 07 can get 80mph 85 at a push but i never rely go past 50mph so i am going to change the sprockets front or back to get of the line farster and to pull the front up without reving the balls out of it . just need to now what's better front or back ? and how meny teeth to add or take off ? and where to get them from i have had a look on the web but no luck thanks your help will be very nice
September 5, 200817 yr Moderator Paul you will need to go smaller on the front to accelrate faster, or bigger on the back, Problem with bigger on the back is your chain might not fit unless you buy a full chain and sprocket kit, which might be your best bet...How worn is your present one?
September 6, 200817 yr Author Paul you will need to go smaller on the front to accelrate faster, or bigger on the back, Problem with bigger on the back is your chain might not fit unless you buy a full chain and sprocket kit, which might be your best bet...How worn is your present one? its only don 4000 miels so its not that worn
September 6, 200817 yr Moderator its only don 4000 miels so its not that worn For now then, try to find a smaller front, I would just go for 1 tooth less if you can find one
September 8, 200817 yr Author i got one from my yamaha shop £5.00 fited it today and wow only one tooth less but what a diferens the front lifts in 1 and 2 very happy top speed has droped by 10 mph but 0 to 60 has improved i would reconmend tis to every one with a dt125x if your not botherd about top speed
