Posted September 4, 200817 yr i'm new to the yamaha scene... i have an 86 yx600. how do i check the level? when i take the cap off the resevoir, there is no level indicator that i can tell. thanks!
September 4, 200817 yr Moderator Is there a glass window on the side of the casing, If so fill it half way in the window, engine stopped, vertical on its wheels.
September 4, 200817 yr Author Is there a glass window on the side of the casing, If so fill it half way in the window, engine stopped, vertical on its wheels. augh, just like my old GL 1000s... apparently i need to do some cleaning to find the glass
