Hello ,
Is it worth restoring ? Not work my bad .
A friend of mine gave me this bike , i'm not sure where to begin . It needs a complete over hall .
Looking it over with out even trying to start it i can see it's going to need alot of work .
It's been sitting out side for 4 or 5 years , plus it was sitting at some back yard bike shop for who knows how long .
As it is i have other projects that are in front of this so i'm in no rush . I'll just buy parts here and there to start .
But is it really worth it ? i don't see many of these bikes around but i also have not looked very long either .
Are parts hard to find ?
your 2 cents will be well considered .
Thanks Joe
it already looks pretty good
I think it would a good fun project to do, it is a yammy aswell so the answer is always yes
sure wish my 86 Radian was in that good of shape when i started on it!
well keep in mind i cleaned it a hit , it was dropped two times , what your not seeing is all the mess , bent hadle bars leaks oil , chan and trans needs to be fixed , battery needed lights broken plus the plastics . Cables missing and god know what else .
Well if you don't want it, give it to me I can give it a good home :rolleyes:
Regards Jim
I ride an FZr1000 and that looks like a sound basis fo a project - but be awae you may have to spend quite a bit for a full restoration. If it was me i would be looking to it over a year with a top-end rebuild, caliper rebuild (funnily enough thee are some refurbed gold calipes on ebay at the mo), cab rebuild and full suspension rebuild. plus new c&s kit, wheel beaings etc.
Go for it, but get eady to use ebay a lot! :D
