September 3, 200817 yr Hello , Is it worth restoring ? Not work my bad . A friend of mine gave me this bike , i'm not sure where to begin . It needs a complete over hall . Looking it over with out even trying to start it i can see it's going to need alot of work . It's been sitting out side for 4 or 5 years , plus it was sitting at some back yard bike shop for who knows how long . As it is i have other projects that are in front of this so i'm in no rush . I'll just buy parts here and there to start . But is it really worth it ? i don't see many of these bikes around but i also have not looked very long either . Are parts hard to find ? your 2 cents will be well considered . Thanks Joe
September 4, 200817 yr it already looks pretty good I think it would a good fun project to do, it is a yammy aswell so the answer is always yes
September 6, 200817 yr Author well keep in mind i cleaned it a hit , it was dropped two times , what your not seeing is all the mess , bent hadle bars leaks oil , chan and trans needs to be fixed , battery needed lights broken plus the plastics . Cables missing and god know what else .
September 7, 200817 yr well keep in mind i cleaned it a hit , it was dropped two times , what your not seeing is all the mess , bent hadle bars leaks oil , chan and trans needs to be fixed , battery needed lights broken plus the plastics . Cables missing and god know what else . Well if you don't want it, give it to me I can give it a good home Regards Jim
September 7, 200817 yr I ride an FZr1000 and that looks like a sound basis fo a project - but be awae you may have to spend quite a bit for a full restoration. If it was me i would be looking to it over a year with a top-end rebuild, caliper rebuild (funnily enough thee are some refurbed gold calipes on ebay at the mo), cab rebuild and full suspension rebuild. plus new c&s kit, wheel beaings etc. Go for it, but get eady to use ebay a lot!
