problem with my dt 175
Sanders
This post is 5918 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
i've got a 78 dt 175. i thought it was seased but i srayed wd-40 in the cylinder and i can kick it now. after about 20 kicks the kick starter won't go down. I believe the problem is the kick starter and not the engine. does anyone have a diagram of how to take apart a kickstarter?
thanks
jim sanders
Link to comment
Share on other sites
thanks
jim sanders
Does this help? Linky
Link to comment
thanks
jim sanders
If you had to spray WD-40 into your cylinder to get it to kick over it may have seized. When you put the bike in a higher gear and roll the bike and let out the clutch will the engine turn over then. If it doesn't I would pull the cylinder and inspect the piston.
Link to comment
  • Recently Browsing
