Posted August 20, 200817 yr Hello, i have just bought this Akrapovic Megaphone Exhaust for my R6. I was told that it lacks power at the bottom end and can be sorted with a power commander is this true?
August 21, 200817 yr Hello, i have just bought this Akrapovic Megaphone Exhaust for my R6. I was told that it lacks power at the bottom end and can be sorted with a power commander is this true? All a power commander does is interupt the temp reading and makes the ecu think it needs richer mix to warm up. You can get the same effect from a 20 pence resitor from Maplins. Either get a dyno run done and get the engine fully mapped or fit "Microsquirt" ECU and get your ride dyno'd and tuned. Microsquirt gives you many more options to set the bike up properly on a dyno
