Posted August 20, 200817 yr Hi all Just got back into biking after 20 yrs or so, bought a new yam yzf r125 great bike but could do with a little more power, can anyone advise me how to derestrict thanks
August 22, 200817 yr Hi all Just got back into biking after 20 yrs or so, bought a new yam yzf r125 great bike but could do with a little more power, can anyone advise me how to derestrict thanks there isnt any restrictor in it, unlike a 2stroke. You would get more power out of it with a RACE PIPE, like any bike. Yammy always aim their 125cc road range at learners rather than full licence holders
August 22, 200817 yr Author there isnt any restrictor in it, unlike a 2stroke. You would get more power out of it with a RACE PIPE, like any bike. Yammy always aim their 125cc road range at learners rather than full licence holders cheers for advice, i will check out and see what i can pick up for a decent price.
August 23, 200817 yr as far as i know .... the r125 is restricted but electronically and ur dealership can remove it as long as uve done ur test and it will ad 5 or 6 horses
September 3, 200816 yr Anybody got a de-restricted R-125 ? Whats it like over the standered etc I'm not aware of any electronic restriction - although not spoken to a dealer. As far as I know benefits from a race pipe would be pretty minimal, mainly weight saving (70% on some of them) and bypasses the cats so you might gain 1 or 2hp?
September 22, 200816 yr Hi all Just got back into biking after 20 yrs or so, bought a new yam yzf r125 great bike but could do with a little more power, can anyone advise me how to derestrict thanks Do Not Derestrict the Bike!! I Did And It Went Bang! And Warrenty Was No Longer Valid. Including The Bike And Parts To Make Itt Faster I Spend Around £4500. Save Your Money!
September 22, 200816 yr Author Do Not Derestrict the Bike!! I Did And It Went Bang! And Warrenty Was No Longer Valid. Including The Bike And Parts To Make Itt Faster I Spend Around £4500. Save Your Money! Thanks for advice, think i will leave well alone and spend money on bigger bike when i've taken test etc. out of interest was the work done by dealer, if it was you might be able to claim something back.
September 22, 200816 yr Do Not De restrict the Bike!! I Did And It Went Bang, how would De restricting the engine make it go bang, have you tried De restricting the air box and have you tried a foam air filter or a cone filter if you do this then you might need to up jet the carb to stop the engine running lean, you could try a different exhaust,
September 23, 200816 yr Do Not De restrict the Bike!! I Did And It Went Bang, how would De restricting the engine make it go bang, have you tried De restricting the air box and have you tried a foam air filter or a cone filter if you do this then you might need to up jet the carb to stop the engine running lean, you could try a different exhaust, I Had Spent Loads On The Bike Had It About 25 bhp Running It To Much And The Engine Couldnt Haddle The Power
December 13, 200816 yr I Had Spent Loads On The Bike Had It About 25 bhp Running It To Much And The Engine Couldnt Haddle The Power If you used a Power Commander to remap bike’s stock fuel injection system after installing all your mods then it wouldn't have run too lean and wouldn't have seized
January 22, 200916 yr It can be de-restricted. I have a thread about it on my website. www.onetwofives.com Then there's the 170cc Kit from Malossi. Not heard anything about the power commander as of yet or how affective it is.
May 4, 200916 yr Hi there, I went to my dealer and found that my yam IS restricted, and they will not de-restrict it unless i show them my full license, now obviously i dont intend on doing my full license just yet, (otherwise i wouldnt be on here). Any help on how to de-restrict the bike whilst still only containing the stock parts would be greatly appreciated. (I know it can be done) Many Thanks
August 31, 200915 yr It can be de-restricted. I have a thread about it on my website. www.onetwofives.com Then there's the 170cc Kit from Malossi. Not heard anything about the power commander as of yet or how affective it is. The link you have posted is for an XBOX360 chipping website and ideas!!
August 31, 200915 yr If your going to look into getting an exhaust then the Leovince exhaust for the r125 claims to give u 30% more torque, and sounds pretty good aswell ian
August 31, 200915 yr Guys dont forget that assuming you weigh 60 Kg, approx 10.5 st, on the YZF-R125, a total of some 200Kg an increase of 1-2 hp is a gain of 5-10 bhp per ton an increase from 75BHP per ton to 85... The standard exhaust weighs something like 4 kilos and a leovince, scorpion weighs a quarter of that which again increases the bhp/ton This bike may be restricted electronicaly but as with a car engine the increase in power comes from tuning.. I have noticed on mine the top of the air filter box has the inlets on the back of it. I've not had the tank off so cannot see the shape of the filter box but it looks like it may be possible to rotate the top through 180 degrees and feed cool air into the box. This could achieve a ram effect! Can anyone confirm if the top of the box can be rotated?
August 4, 201114 yr Guys dont forget that assuming you weigh 60 Kg, approx 10.5 st, on the YZF-R125, a total of some 200Kg an increase of 1-2 hp is a gain of 5-10 bhp per ton an increase from 75BHP per ton to 85... The standard exhaust weighs something like 4 kilos and a leovince, scorpion weighs a quarter of that which again increases the bhp/ton This bike may be restricted electronicaly but as with a car engine the increase in power comes from tuning.. I have noticed on mine the top of the air filter box has the inlets on the back of it. I've not had the tank off so cannot see the shape of the filter box but it looks like it may be possible to rotate the top through 180 degrees and feed cool air into the box. This could achieve a ram effect! Can anyone confirm if the top of the box can be rotated? can't be rotated lol
