Thundercat starts on choke but will not run on throttle
Roadrunner205
This post is 5929 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Every year i put my Bandit away for winter and every spring its like this, will only run and idle with a little choke, blip the throttle and it dies. All i do is warm it up properly then its 'Right as Ninepence' could this be the same?
Might be wise to check your plug gaps as well, It they're too big it wont help.
Link to comment
Share on other sites
yeah, just happened with my FZ; before the carbs started leaking... i just let it idle for like five minutes and just rolled one finger over the throttle a little bit more and then more and now it revs fine.
Probably a plugged jet needed time to be cleared.
Link to comment
  • Recently Browsing
