DT Dep pipe leaking
Whilst cleaning the bike over the weekend i noticed that there has been an oil leak around the header pipe throughing oil over my engine casing.
Has anyone had this before and how could i solve this?
TIA
TIA
hey iv got the same problem after riding for a bit the whole underside of the casing is covered in oil from the leaking DEP pipe im planning on making a copper eye shape gasket to go over the whole thing around the manifold
its a bit bad how that looks like a common problem, i thought maybe gasket needed renewing but doesnt seem to be anything wrong with it,
Might try what your doing with the copper washe cause the oil looks a mess defs isnt right.
Just a thought,
i might try a bit of instant gasket and see how that goes 1st
Just a thought,
hmm yer could work i wasnt on about a copper washer i was talking a gasket to cover to whole mating surface then cut a hole for the bit of the dep pipe that sticks out to go through its a big eye shape :D let me no how u get on
Just a thought,
Oright yeah i see what you mean cause it doesnt seem to fit perfectly flush does it,
It came with washers or the flange but when you put them on they get caught on the exhaust itself so dont actually fit so i used them as washers else where lol
But yeah it does seem to be missing a flange. <_<
haha thats exactly what i did use the washers else where lol. how fast is urs?
yep let me no how u get on
Well before the dep pipe i got about 80mph now with it absolute pinned about 85mph (nearly maxing the speedo) but better aceleration.
I only found this by racing an rx125 and dare held it there 4 longer than 2seconds lol so i rarely go over 75mph to be honest.
you?
  • 7 months later...
i solved the problem with my exhaust leaking with i rubber ring, i got 1 that was just a lil bit bigger than the hole and forced it in and i have had no problem since, so thats another option for ya
