xt600
hello all.
i have a poblem with my xt600
have him for 3 months and spend houres working on him.
now the motor turns nice, but if i put him in 1st or 2 nd the motor stops running. even with the clutch held in.
i found the killerswitch allready and bypassed it ( hope that will do ) i found out that the switch gave no contact when pulled out and broke the contact when was pushed in , so i shunted it
anyone that had the same problem ???
hello all.
Hi
Is there a side stand switch? Check that this is working or bypass the switch.
good luck
:D:D:D
Hi
good luck
:D:D:D
hello fosdyke,
yes there is a side stand switch
i bypassed it by connecting the two ends of teh cable together
but still the same result
does somebody has a plan of the wires, than i can figure out where the problem is,
i suppose that it is in thi sdirrection i should look
Yep :yeahthat:
hello oldgitonabike,
