Posted August 8, 200817 yr Been out on my 2000 R6 earlier today, all was well untill i started giving it some grief then it just lost power and was spluttering sounding like a twin and cutting out when i was stopped i also noticed that the temp was lower than usual..... i stopped the bike left for a bit then when i got back on it was okay then just kept happening every now and then!!! Does anyone have a clue what it could be?? It seems like plugs so will try that tomorrow!! Any help would be much appreciated!! Paul
August 8, 200817 yr My guess is a plug or two have died (if not firing, there is no detination, so less heat), or a coil or two have expired. Former is a pain to change, the latter is much much easier. Either way, its nothing serious. I doubt it anyway.
August 9, 200817 yr either your plugs are fouled or have given up , possibly your fuel is gone off . i'd go over your electricals & fueling , if nothing else get it checked out by a motorcycle mechanic ..
August 9, 200816 yr Author thanks for the help guys i'll try and have a look tomorrow, hopefully it is one of those things so it dont cost me too much lol
August 9, 200816 yr Been out on my 2000 R6 earlier today, all was well untill i started giving it some grief then it just lost power and was spluttering sounding like a twin and cutting out when i was stopped i also noticed that the temp was lower than usual..... i stopped the bike left for a bit then when i got back on it was okay then just kept happening every now and then!!! Does anyone have a clue what it could be?? It seems like plugs so will try that tomorrow!! Any help would be much appreciated!! Paul I would also check the coolant level when cold. It could be a head gasket.
August 10, 200816 yr Author just had the bike apart and noticed that the fuel line after the inline filter had a big kink in it!! Changed the pipe now and it seems ok gonna take it for a blast when the weather clears up and see if its cured!!
