yamaha led indicators
please can anyone help i have fitted a bike it led rear light with built in indicators and also bike it led front indicators and there relay problem is when lights are on rear indicators are only half illuminated but when lights are off rear indicators light up fully need help as i had to mot it for daylight use only
  • 3 weeks later...
did you change your relays to suit led indicators?if its not that, could be a fault with the rear led panel only guessing here but it sounds like a earth/negative problem on the led
