Posted August 4, 200817 yr Hi, Looking to move on from my '94 YZF750 onto something a: Newer, b: More powerful, and c: better for two up touring. The only thing is, I want something that will satisfy my weekend warrior aspirations and scratch as well as the YFZ. I'm not a nutter but I would like something that isn't going to be left behind. I reckon the old ThunderAce will fit the bill, anyone got any comments or experiences that would change my mind or confirm my choice? Cheers, Lard
August 5, 200817 yr I`ve just done the same, changed my YZF750 for a Thunderace. Its much more comfortable, ideal for touring, has a good torquey motor, good for an actual 165mph. Only downside compared to the YZF750, its a bit heavier and the rear original suspension isn`t very good. Front end is good, as the internals are virtually the same as the R1. Usual problems with Exup valve seizing, and exhaust headers rot, but i replaced mine with a stainless system with no Exup valve, no rejetting, actually improves the mid range a little. Some have problems with running hot and boiling over, easily fixed with a different thermostat or a manual switch for the fans. Most Aces use a lot of oil, though mines fine at the moment. Replacement panels are expensive, even secondhand, especially top fairings. Clutch can be a little grabby, but can be fixed replacing the master cylinder with one from a YZF750. Not everyones cup of tea as some say they look a bit fat and wide, but i`m happy with mine.
