YG1
Hi All,
I've recently bought a non running YG1 and have discovered that the clutch actuating lever (that is inside the crankcase cover is missing)
The part is discontinued, does anyone have one kicking around that they would be either willing to sell or loan me so I can get something engineered, I would be willing to pay any carriage charges
regards
Wombledog
Hi All,
regards
Wombledog
Hi,
Ignore this link if you already know about it:
http://www.cmsnl.com/yamaha-yg1-1964-_model8289/partslist/
I've just started restoring a YJ1 1965 so know how you feel, I need a few parts myself :blink:
All the best.
  • 4 weeks later...
Hi,
All the best.
i have just bought 2 yg1 80 cc basket cases do you still require this part if so will have a look for it as the bikes are in pieces oh by the way how closely relayed to the fs1e are the engines,as i may require crank and piston 0r do rd 8o bits fit
Hi Yamahanut,
Fs1 is simular but did not share too many common parts RD80's bear no resembelance to YG1's at all (YG being a disk valve engine & RD being a reed valve). Closer to the YG is perhaps the YB100.
With Cycle parts you should beable to fit/modify FS1 bits in order to rebuild them try http://www.fs1shop.nl for bits the seam to have alsorts of old bits but you do need to email them as the site only shows their new stock
Regards Jim
  • 4 years later...
Hey guys I own a super nice 1963 1/2 Yg1 unrestored, so I don't need parts but owners manual, but don't want to spend $75 + for one, you know recommend'd oil, how much ect. It's pre oil injected model & there isn't any info out there so if any one can help I would be grateful, thanks. Now for you guys that need parts one of the biggest NOS stock piles is at st. louis donalson cycles been Yamaha dealer since 1962 & has kept all his old stock :) make sure you talk to Carl,, hope this helps good luck
Just bought a yg1 myself no workshop manual sorry .I did read somewhere recent the oil petrol mix is 30 to1 ratio if this helps,
