Adjusting the accelarator cable?
I changed the bars on my bike and now the gears rev too much before kicking in.
Is the cable supposed to be taught or something?
Help please.
Thankyou ill give it a try.
Dont mean to sound ungrateful but it seems to me its almost the opposite.
Can the cable be too loose?
Sorry was watching Big Brother...
My god you really do need help :P
Its revving its nuts off now youve rebuilt it?
are the new bars wider than the old ones?
Does it rev more when you move the bars from lock to lock?
Oh sorry...
Not really revving too much.
Revs in a straight line.
I mean its quite rideable and 1st and 2nd are worse.(2nd is kick ass on these...usually anyway)
Im getting confused with this now, i thought that it was revving too much
Cant you be more precise with whats wrong
Revs in a straight line?...dont understand
I mean its quite rideable and 1st and 2nd are worse.(2nd is kick ass on these...usually anyway?...dont understand this either
Not really revving too much.?...Thought it was
Its been a long day, c'mon
Sorry I am trying.....
The best way I can describe it is like when a clutch is wearing out on a car.
You get the revs before the gear engages whereas is should be at the same time.
Does that make sense?
(and I do appreciate your patience and help)
All this time i'm thinking its a throttle, engine revving fault!
OK with the bike in neutral can you rev the engine as normal and twist the bars from lock to lock without the revs increasing?
Just tried.
Yes.
so there is absolutely nothing wrong with the throttle cable, it does the job you want it to ?
But when you put the bike in gear and let the clutch out, there is a delay before the bike moves forward, which results in the engine revving up too much?
Yes thats it.
It happens with 1st,2nd and a little less each time down through the gears.
(reverse has stopped working altogether...Joke)
Yes thats it.
:lol:
Right, there should be a little free play at the clutch lever before it begins to pull the cable
check it with the bars at left lock, centre, and right lock
