yzf 750 flat spot cured
:D After years of suffering a flat spot between 4-5,000 revs its been cured by a 2p bit of wire .
Following a previous posting I got a reply from Sniffer who I am now forever in debt to
He put me in touch with a guy called Shane at B&B Motorcycles Barnsley 01226 391557
who explained that on the large mulit pin socket on the ECU there is a empty pin (top row right hand side)
simply fix a wire into this empty socket and run it to earth,he battery will do fine,
Then switch the ignition on and off three times this remaps the ECU or activates a dormant map in the ECU
either way it works a treat!
The power is now smooth all the way from tick over up with no stumbling or holding back
RESULT!!!! :D:D
