Posted July 29, 200817 yr hi all just had a quick look around on the net but unable to find any relevant info... i have a yamaha fazer 600 (1999), i started it this morning and noticed petrol pouring from the joint at the bottom of the tail can! upon further investigation i found the petrol has also become mixed with the oil and there is also petrol inside the airbox!! there was also petrol coming from the carb breather pipe. my intial thoughts are it may be something related to the piston rings, although im not certain as i would have thought this would have been noticed earlier (i.e. blue smoke from exhaust) and this seems to have happened suddenly. are there any common faults that would cause this or does anyone know of any seals or gaksets that may have failed that may cause this to happen? any help much appreciated!! regards gareth
July 29, 200817 yr Could be the carbs flooding causing fuel to drain into the airbox and engine, could just be a sticking float needle valve. Also fuel tap could be leaking causing fuel to flow when its not required. Not familiar with the bike and its fuel delivery method but might give you something to look at.
July 29, 200817 yr Most likely via flooding carbs BUT that bike has a fuel pump, should only be sending fuel into the machine when the engine is running (and the fuel pump is running). Have a look here http://fazerowners.yuku.com/bfazerowners introduce yourself, do a forum search and post a query if you can't find anything to help... Paul
July 30, 200817 yr Author cheers guys, sticking float valve seems to be the common fault that has been suggested so will have a go at stripping the carbs on the weekend. cheers!
