Rev counter needle
Hi,
Strange problem with my rev counter in that the needle has gone below the zero stop.
With the ignition off it hangs in the middle of the dial.
Switch on it the moves to below the stop then it cant move any more,
Do i need to strip the dial and just lever the needle above the stop or is it electroncally adjusted on a pendulum.
Cheers Chris.
It probably works on a drag cup. There will be a spinning magnet under the needle cup, so that's where to look.
Hi,
Cheers Chris.
there's a company called re-dial in the uk who can repair re-face your dials
