81 400 special running lights and throttle issues
RSF
This post is 5781 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Basically, you use a large jewelery cleaner. They have some made specifically for carbs, but they are expensive.
I think Drewpy recommended this one; http://www.aldi.co.uk/uk/html/offers/58_5123.htm
only cos its cheap. used it the other day and it works a treat, used warm water and a surficant cleaner (w/up liquid type stuff but no salt)
more expensive ones have a heater and larger capacity for speed, i just turn the part around just takes longer.
does that mean you sing whilst you clean them? :lol::D:D:lol::D
yeah like that opera bird on luc besson's 5th element film!
Can you fit two carbs in there, or do you seperate them to fit? I've got to get one of these!
you have to strip the carbs down.
you can do all the jets ans the carbs would have to be turned over. larger more expensive ones you can immerse the whole carb in it
