XT250G 1980 carb settings
Can anyone let me know which slot the clip should be fitted onto on the needle valve of a 1980 XT250G?
Thanks Nick
Hi Nick,
Don't know exactly what set up your've got on your bike but as a rule of thumb for a standard airbox and pipe
the clip usually goes on the middle slot then its just a case of tuning the carb to get the best results for your bike if you have standard jets in your carb?
hope this helps
Bill
Hi Nick,
hope this helps
Bill
Thanks Bill - bike is completely standard with it being just rebuild for new cam chain/bearing, and I fitted a Keyster carb refurb kit when stripped the engine.
It coughs and misfires when the throttle is opened and will not rev, so wanted to make sure I had put the circlip in the right place.
I am going to check the float height as it feels like fuel starvation but wanted to be sure I hadn't got the needle setting miles off.
Thanks for your advice Nick
According to the Yamaha service data book i have the XT250 needle clip position should be in the 3rd groove down from the top. Main jet #165. Air screw 2 and 1/2 turns out. Hope this is of some help .Tony.
Thanks Tony - I will check it this evening.
Nick
