tzr 50 oil and water light
I recently got a tzr 50 its a 2003 model.
When I rev it up the oil and water temp light gets brighter.
Any1 know whats wrong.
Have you checked the levels, they should be topped up to the max-mark.
If you switch the headlights on, do the warning lights dim?
The levels are fine. The headlights go on when the bike starts and cant switch off.
  • 1 month later...
When I rev it up the oil and water temp light gets brighter. this might mean the regulator rectifier is on the way out
