July 23, 200817 yr I recently got a tzr 50 its a 2003 model. When I rev it up the oil and water temp light gets brighter. Any1 know whats wrong.
July 23, 200817 yr I recently got a tzr 50 its a 2003 model. When I rev it up the oil and water temp light gets brighter. Any1 know whats wrong. Have you checked the levels, they should be topped up to the max-mark. If you switch the headlights on, do the warning lights dim?
July 23, 200817 yr Author Have you checked the levels, they should be topped up to the max-mark. If you switch the headlights on, do the warning lights dim? The levels are fine. The headlights go on when the bike starts and cant switch off.
September 18, 200817 yr When I rev it up the oil and water temp light gets brighter. this might mean the regulator rectifier is on the way out
