Fuel Additives --- should I, shouldn't I...
I would like to know which brand / type of fuel additive you would recommend.
It's a 2003 R1 and has done about 16700 miles now and I think it's time to clear her throat.
Thanks.
Thanks.
NONE!!!
A good service (Change Oil, filters and plugs), some high octane unleaded( The really expensive one) from the pumps should be fine. Shes not even run in yet. ;)
OK, none it is then!
Thanx for the advice.
Cheers
I use Redex in my Bandit 400 - but she is getting on a bit lol
Ive used it in my 2004 Dragstar too and seems to clear out the crap.
Wont do it any harm to be honest if you cant be arsed with a full service
NONE!!!
On the subject of fuel (rather than additives); I put some 99 octane superplus in the TDM this week, as there was nothing else at the garage at the time. So; should I use it regularly to turn my camel into a thoroughbred, would it make no discernible difference, or would it ultimately demolish the engine?
Ypu should see a increase in mpg. i got an extra 50 when i used shell optimax in my ybr
