Jets
Right iv got a Dep pipe on order and im thinking of upping the jet size but the only thing is im not sure what size to go/try.
Any help would help and also where i could get some from.
Thanks in advance,
Just thought id add its just a mikuni carb.
Hi Ryan,
usually if your carb needs to be rejetted the manufacturer of the pipe will tell you and recommened what size jet to put in ! But on most occasions unless your also changing your filter like putting on a K&N you don't need to? but as a general rule you should up your main jet by 10% then it's just trail/ error and adjustment to get it running properly
Hope this helps you
Regards
Bill
Thanks in advance,
Iv got fhe DTR E125 06 i put a dep system on my bike a few weeks ago and if i were you i would leave the jets my bike runs great with the dep pipe on and the standard jets in.
